The thickness of the grasshopper stroke preview seems to have increased. Is there a way to revert it to how it was in R8?
r8(left) - r9(right)
It is a different formula in 9, scaleDPI + 1 if i recall
hi @Japhy will there be a change made regarding this?
Hi hesro,
RH-99651 GH1 preview wires much thicker in Rhino 9
A display mode gets you most of the way back. Copy Shaded in Options > View > Display Modes, then in the copy set Objects > Curves > Curve width to Pixels 1 and Objects > Surfaces > Edge thickness to Pixels 1. That takes the GH preview down to about 2 px.
GH-Classic.ini (8.5 KB)
RH-99651 is fixed in Rhino 9 Service Release 1
Where to do these settings? Can you please share a screenshot of the same?
Hi @Japhy
the problem is still there.
Drop the scale to 0
@Japhy I think what @hesro was trying to say/show is that up until v8, GH curve thickness was not tied to or effected by rhino displaymode settings.
starting with v9, rhino curve settings directly effects the GH curves
ideally, GH should have it’s own curve thickness setting.
(btw, scale 0 will make all rhino curves disappear)
This would be a much more user-friendly approach, but for now, at least, it would be enough if it didn’t add extra thickness to the Rhino display mode.
I still get a very thin line at 0, albeit pixalated, 1px it is then (originally it was Scale+1, which our RH-99651 removed)
I don’t know the history on the original change to apply display modes. The primary benefit is that It gives the user more control previews.
Apparently, this is still an issue in version 9.1. Maybe it’s been fixed in version 9.2.![]()
I agree with the others in this thread that I preferred the way this worked in Rhino 8. I’d like to see the same line/edge thickness for Rhino objects and grasshopper objects.
In Rhino 8, the user already had control over grasshopper previews on a per object basis by using native grasshopper components ("Curve Preview"and “Custom Preview”) and plug-ins.
-Kevin
