I have a GH Player file that is subdividing a surface and adding some info to the points. I can enter the number of U and V divisions. I have the preview enabled on a data parameter where the points are. If I test out the GH script it updates the points preview just fine.
But in the Grasshopper player file the preview I get of the points just stays on the default values even if I change the U or V value.
So how come it does not update? How can I force it to do so?
Here is the parameter that is used for preview:
ps: side note to @DavidRutten: for GH2 can you make it so you can tell which component is set to preview or not even when it is orange? Especially with GH Player usually all the components are orange and then you can’t tell which ones are previewing.
