Grasshopper panel font size - global change?
I have a definition with a bunch of panels where the fonts seem to have gotten too large - or this might be something that changed over time as this definition is rather old.
I tried right clicking on one panel, changing the size to what I want - then again using Adjust Defaults> Make Font Default, but that didn’t do it for the rest of the panels… How to do this globally?
This old script might help get you started:
200817_DecreaseOrIncreasePanelFontSizes_00.gh (5.0 KB)
If I recall, it throws a warning at first due to the sloppy ExpireSolution implementation. And it doesn’t allow one to explicitly set the font size. Though that should be a trivial update I suspect.
OK, thanks, looks like GH for V8 has a third setting for all panels that GH for V7 does not.
There we go, explicitly setting the font type and size:
240112_SetPanelsFontNameSize_00.gh (5.2 KB)
Tremendous. Thank you for this.
