I am currently facing an issue with Grasshopper in Rhino where only the “Params” tab is visible upon launch, while all other standard tabs such as “Math”, “Sets”, “Vector”, “Surface”, etc., are missing.
Started having the same issue recently. GrasshopperLoadOneByOne does fix it but it would be great to know what the culprit is. Haven’t installed any new plugins in a long time.
The command line shows no errors for me either. That being said, I’ve checked and seen that the new versions work for me in Rhino 8, my issue is exclusive to Rhino.Inside Revit. Not sure if that’s also @Vijayaraj_N 's case.
For reference my current version is:
Hmm, i did a boo boo, and no idea what is happening…
One thing I see that you have OpenNest1 alongside OpenNest2.
The only thing that comes to my mind are guids duplicates. But I am not sure if this is a problem.
But nope opennest1 together with opennest2 works withoiut problem on my Rhino8:
