I’ve been working on GhostGPU, an experimental Grasshopper plugin aimed at offloading heavy computation to the GPU.
The core idea is simple: upload data once, keep intermediate results in GPU memory, and pass buffer handles between nodes. Host-to-device transfers and viewport previews are treated as explicit boundaries rather than happening implicitly at every step.
For a benchmark run, I used a setup with 66,049 vertices and two attractors (covering closest points, vector construction, remapping, amplitude, mesh displacement, and vertex coloring), then rebuilt the identical logic using native Grasshopper nodes for comparison.
Running on an RTX 3050 Ti Laptop GPU, the GPU cluster clocked in at 36 ms compared to 722 ms on the standard CPU components. These are single profiler readings, so I am still testing repeatability, caching behavior, and memory transfer overhead before making broader performance claims.
For those dealing with heavy definitions in real projects: where are your biggest computational bottlenecks? I’d like the next batch of nodes to target workflows people actually struggle with.
