How to offset a single surface in polysurface (cube) to the rest of the surfaces followed by that offset (grasshopper)? For now, I have disconnected surface and rest of neighbours are on old positions.
offset_srf.gh (6.1 KB)
I guess you have a misconception about display in GH.
If you don’t want to see the previous geometries after you moved at the final step, then just disable all the previous components previews in your definition.
Thanks.
Could you also answer my main question?
I want to offset only one face and the rest should follow.
Is that possible in GH?
I don’t quite understand your question. Please elaborate with a sketch or whatever…
I guess he is trying to use MoveFace or something similar
Yes but I`ve thought that offset is qual to push out by normal direction. My bad.
Is it possible to move the surface in GH the same as this:
