Grasshopper Monoceros "Can't create a module in a proper way"
Hi everyone,
I was using Monocero for a relatively short time, and it worked well while my geometry fit into a single module. However, when I am exploring this type of module built-up way, the geometry just simply cannot fit into my module perfectly. I believe it is a precision problem, but neither did I change this precision in Slice Geo
a.gh (13.5 KB)
, nor the unit in Rhino does not work for it.
It is being solved. For those who also meet the same problems, manually setting your own point is the safest way.
