Grasshopper_ Mapping Object Multiple Times Within a Void
Hello everyone,
I hope you’re doing well.
I have a question about coding in Grasshopper. I’m looking for a simple and efficient way to multiply an object to fill a void, ensuring that the objects don’t overlap the edges or touch each other. The objects should be evenly spread both vertically and horizontally but placed in a random pattern.
I’ve previously mapped objects onto a surface, but never within a void, so I’m wondering if there’s a way to achieve this. I’ve attached a sketch showing how I imagine the cubes would fill the void.
Any help would be greatly appreciated!
Thank you!
I have been thinking, to set them out at random spacing inside a surface, there is the coding around. and it works ! but is there a way to assign them to be copied along the x and y axis at a set distance and then letting them cascade down at different height without touching one another. Would the setting them out into a grid have to be done before jumping onto coding?
not a complete solution but you can build on this further.
you can control the logic for populate3D to suit your needs by calculating the point spacing (so the objects dont collide)
Thank you so much! Was trying to do it using Chatgpt but I can’t trust it too much as it starts giving me errors later on!
