Hi guys,
As you know, Grasshopper always runs in the behind and sometimes (a lot of times actually) that is not something I want, especially when generating native Revit geometry. As a solution to this, I was using Stream Filter and connect Button to its gate when I was going to do something that takes a lot of power.
With the new Element Tracking that came with RC 1.0, I simply cant use this method anymore because when gate turns False it deletes the created elements.
What is your method to create Revit elements manually?
