How is a loft like the image above feasible in Grasshopper??
First adjusting the curve seam and than simply lofting the curves should work.
Maybe you need to split the curve at the new seam too?
How adjusting the curve seam for loft in grasshopperโฆ?
Hello
Follow what @diff-arch explain.
it is not done in loft but with a dedicated component.
Thank you very much for your kind reply. Is it possible to apply the formula you provided to make such a change in the opposite direction?
My explanation was lacking, haha. In the image you showed, a change occurs on one of the four faces, but Iโm talking about making changes on two of the four faces at the same time.
Which ones?
I was wondering if it would be possible to make a loft transformation like this image on both sides!
Wow, you seem more competent than my professor. Thank you so much.
