hi i made some shape and i’d like use lines around it
I want to change the twisted vertical lines vertically.
anyone has idea to sort the lines?
Hi.
It seems that this definition is not yours but what I posted on the old GH forum, so if possible, it would be better to identify the source of the definition.
hi HS_Kim
yeah definition i got from old forum
thanks for definition and this one too
i made some frame using attached definition
It’s a bit complicated GH file, and I do not think the vertical and horizontal connections are smooth.
Could it be more efficient to use a lunch box?
If so, thank you for helping.
0529 spiral frame.gh (36.6 KB)
thanks a lot !
hi i’d like to select the points in the restricted area
And i want to reduce the number of first and last 2~3 groups of points selected on the z axis
I want to reduce the direction of declining from the center to the outside
Can anyone help me apply the graph mapper?
0531 inside.gh (22.1 KB)
I’m approaching my goal to some extent.
Can the effect of the Graph Mapper be applied to both sides along the bottom middle axis?
0601 inside.gh (30.3 KB)
