Grasshopper - kerf bending
I was referring to my version, as the angle varies the thickness of the rectangles also varies slightly.
I need angles, how does this show them? Kerf Spacing Bending Wood - Metric
No, you don’t. On a straight board (before bending), you need start and end points and the number of cuts. Sounds to me like you need a long walk to clear your head :bangbang:
your method avoids this need
what is the kerf width in your method?
If you can’t read the code, you are in deep trouble. I’m done, goodbye.
Determines the depth of the cut starting from set measurements.
bending a.gh (41.0 KB)
You did a great job, thanks!
brilliant, thanks! :slight_smile:
A edit only for better graphical representation.
bending a.gh (46.8 KB)
