Grasshopper Job
Hello All
I couldn’t find a GH specific job board - happy to move this post if there is one?
We are looking for help to automate some parts of our current mold design process. Looking at using Grasshopper to build 3D printed investment casting shells using shrinkwrap off-sets.
We’d like to run a process similar to this:
  • Import part file (STEP format)
  • Generate shell (variable thickness)
  • Find and generate a split line
  • Create lugs on split face (user defined positions)
  • (Bonus feature: Convert internal features into cores)
  • Export as a STEP
If you believe you can build this for us we would be keen to talk.
Cheers
David
could you provide an example—perhaps a STEP file or an image to start with—regarding the variable thickness aspect? I’m having trouble understanding it; does it refer to the thickness of the part itself? I’ve made many molds—some for casting, but mostly for composites—so what exactly do you mean by “lugs”?
Cheers
F.B
Hi David,
I’m a Grasshopper developer with over 25 years of experience in composites, injection molding, and investment casting.
Your project sounds very achievable and is similar to tools I’ve developed for both my own workflows and for clients.
I’ll send you a DM with my contact details.
Thanks,
David Kay
FWIW I came across this one the other day
Object is a small studio doing geometry automation - we take engineering know-how that sits in specialists’ heads and turn it into software: parametric pipelines in Rhino/Grasshopper, headless geometry services on Rhino.Compute and our own libraries, and the interfaces around them, usually ending at a machine. Around twenty projects so far across medical, additive manufacturing, shipbuilding, CNC and AEC. We also publish GH plugins - Anemone, Owl, Starling and more.
What you’re describing is that kind of pipeline, with the split line and the BRep-versus-mesh question at the export deciding most of the effort.
What we do: Automation & Modeling — Eliminate repetitive CAD tasks | Object
Case studies: Stories — Client Case Studies | Object
Happy to talk - hi@object.pl
Mateusz
Thank you all for your responses here and through direct contact.
I think we have a plan in place now.
My apologies if I didn’t get to respond to your message yet.
