Hey there!
I’ve got an issue which has appeared recently after the RIR update:
While i am working inside the Grasshopper Canvas it executes the solution in a common way, as it used to be. But as i am leaving the Canvas (e.g. when i am clicking onto the Revit’s viewport), Grasshopper starts to execute the solution over and over again and only the solver block helps.
The problem is getting worse in the situations, when i am running the Revit API transactions (especially when i need to move some objects using DB.ElementTransformUtils, so that the objects are just running away iteration after iteration)
Thanks in advance!
