Grasshopper in Rhino 8 WIP - Extrude Component Doesn't Work
You got options…
Using the Boundary Surface component, you know your curves are co-planar. Otherwise the component would fail.
Using Loft, you can convert the brep into a trimmed surface using the Merge Faces component. If the result is a single trimmed surface, you also know the input curves are co-planar.
Extrude Open Brep Issue.gh (18.3 KB)
Hi Martin, the solution to merge faces after the loft is genial and solves all my problems because I can use it in both situations. Thanks a lot for your reply!
RH-76758 is fixed in Rhino 8 Service Release 2 Release Candidate
