Grasshopper 'imaging-library' fills of multiple nested curves
Hi I’m trying to export a jpg using the imaging-library plugin but I have multiple nested curves. As the only accepted inputs are curves rather than surfaces any nested curves are irrelevent when fills are applied to the outer most curve.
It would be much easier if a surface input was possible in this instance.
Otherwise - anyone have any suggestions on the easiest way to sort nested curves in order to construct layered fills to acheive the desired effect?
2023-06-09_imaging-library_Nested_Crvs.gh (8.7 KB)
2023-06-09_imaging-library_Nested_Crvs.3dm (2.8 MB)
It needs tidying up - and reworking so that it can handle n-number of nested curves - but this is at least working. I’m sure there’s a simpler way to do it though…
2023-06-09_imaging-library_Nested_Crvs_WIP.3dm (2.9 MB)
2023-06-09_imaging-library_Nested_Crvs_WIP.gh (21.3 KB)
