I’m a beginner in grasshopper and I try to make a script in which I have a cylindric form with variable radii. Then I want to subtract multiple extruded curves.
Grasshopper forgets some curves in some specific radii and I don’t understand why - because they are in “Kurven A” included.
I would be happy if anyone can help.
Thanks
it doesn’t look like any solid is missing, I’m on Rhino 7.7.21145.13001, 2021-05-25
in the attached file I have internalized the final Brep resulting from the boolean operations, so you can check if it’s identical to the final solution you get:
