I was just reminded about this 11 years old plug in.
https://www.grasshopper3d.com/profiles/blogs/gumball-for-grasshopper
Forked it and asked ai to rewrite it for NET8, and add some features. Amazing stuff, works great, try it.
Wow, great work! Thanks!
Yeah snapping to curves and points. to provided geometry from grasshopper. Wiring it to all rhino geometry/ all gh geometry is a complex task. Also no projections/intersections snapping
i been using it all time thanks for the updated version with new features
Between this and telepethy2, you are on a role! By the way, this seems to only be available on the WIP and not Rhino 8.
No it is made for rhino 8. Not sure what is happening, try to install like normal gh plug in, use this gha
GumballGH.gha (71 KB)
Thank you very much.
Updated the plug in to version 2.1.0
For last two components to work you have to select them in grasshopper. It is made like this on purpose
Some more examples, same as in the original post.
Not to replace the original features, but, just so you know, possible in rhino 8 too..
Glad you like it. Yeah i have been working on this one for the past couple days. You can explore some of its capabilities by right clicking. It has rectangle selection as well (+ shift and + control for only adding to selection and for only removing from selection). Also all components including this one have cache, and proximity cache (objects selection is remembered not by their index, but based on centroid position), so you can have selection saved despite shifted tree, or even keep objects selected that disappeared from a list and then returned. It is not perfect, but it is kind of a stable guid.
I need some feedback on that, any bugs, ideas. Any other components of similar kind
Yes I have an idea for a drop down menu similar to AutoCAD block parameters. After you select something, a menu option pops up that will allow the user to change the parameters of that object.
Like what parameters for example?
