G Gold.rui (6.7 MB)
remade. start script button. will help to avoid the problem.
Replace the toolbar.
press the help button and watch the video.
you must first use the command _SnapToMeshObject
OK nice. Just question this little cros inside gems on mesh its possibile to remove gem when i place it on wrong place? or move it ? And when i pres create its possible to place gems like from begining just different size?
Send a ring for verification.
I checked everything works for me. Rhino 7
but I corrected the tool a bit. replace the file in the folder. C:\Grasshopper Gold\Ring Resizer
RING RESIZER.gh (111.3 KB)
also on each instrument there is a help button. which will show the video of the work.
and it is also better to use the STL model.
It seems you’ve really done a good job. Thank you for your time and work. Unfortunately it doesn’t work on my rhino 6
Amazing! Is it easy to use for someone who is new to grasshopper?
Wow, Just wow! Thank you so much.
This saves me a TON of time and it’s helping me learn grasshopper as well.
I’m gonna have to throw some $ your way.
Thank you again!
@taraskydon Object on Curve command: the objects do not go to the end of the selected curve. Is this a bug or am I using it wrong?
objectoncurve.3dm (925.1 KB)
