Grasshopper generating RhinoDotNetCrash.txt at desktop when closing a file
Hi all,
Every time I close a GH file, it creates a RhinoDotNetCrash.txt on my desktop. I already tried to uninstall and go back to the SR version without luck. I suspect it started either after installation of the latest Rhino SRC or Windows update as I did them both around the same time.
Looks like it is caused by the Bifocals plug-in because as soon as I “uninstall” (read delete) the file, I no longer get the RhinoDotNetCrash.txt file.
Please see info below:
SystemInfo:
Rhino 6 SR30 2020-8-26 (Rhino 6, 6.30.20239.17111) (deleted)
License type: Commercial, build 2020-08-26
License details: Cloud Zoo. In use by: (deleted)
Windows 10.0 Pro Version 2004 64-bit (Physical RAM: 32Gb)
OS build: 19041.488
Machine name: (deleted)
Hybrid graphics system.
Primary display: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 8-5-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2080 (NVidia) Memory: 8GB, Driver date: 8-12-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.06
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-12-2020
Driver Version: 27.21.14.5206
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.30.20239.17111
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.30.20239.17111
C:\Users\Omeninho\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Panther\Panther.rhp “Panther” 1.0.2007.8
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.30.20239.17111
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.30.20239.17111
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18353.6521\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5” 5.5.18353.6521
RhinoDotNetCrash.txt file content:
[ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object.
at Bifocals.BifocalsComponent.removeAnnotations()
at Bifocals.BifocalsComponent.Doc_ObjectsDeleted(Object sender, GH_DocObjectEventArgs e)
at Grasshopper.Kernel.GH_Document.OnObjectsDeleted(IEnumerable1 doc_objects) at Grasshopper.Kernel.GH_Document.RemoveObjects(IEnumerable1 objectList, Boolean update)
at Grasshopper.Kernel.GH_Document.Dispose(Boolean disposing)
at Grasshopper.Kernel.GH_DocumentServer.RemoveDocument(GH_Document document)
at Grasshopper.Kernel.GH_DocumentServer.SafeRemoveDocument(GH_Document document)
at Grasshopper.GUI.GH_DocumentEditor.MnuCloseClick(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
[END ERROR]
Any input on how to overcome this small issue is much appreciated.
Cheers,
Rick.
Remove Bifocals then.
It seems Bifocals mishandles when there’s no active document.
You can’t do anything, apart from uninstalling Bifocals. The Bifocals developer can fix the issue, and I can put extra error handling around the event which is ultimately causing Bifocals to throw the exception. (I’ve just done that, the next Rhino7 release will have this additional protection).
@Keyu and David: Thanks a lot for the feedback and info provided, much appreciated. It brings me a certain relief to know that the “culprit” is not at Rhino´s end as I was worried that I had messed up my installation after the SRC and Windows Updates.
Cheers!
Rick.
