Grasshopper.Folders.UserObjectFolders no longer exists
I believe my Rhino 8 updated today and now my Py3 scripts are broken: the line Grasshopper.Folders.UserObjectFolders[0] gives an AttributeError: type object 'Folders' has no attribute 'UserObjectFolders' which it didn’t previously. The API reference indicates that the UserObjectFolders property should still exist: Folders Class
Curiously, some attributes like work, including Grasshopper.Folders.LocalAppDataFolder, which now points to a Grasshopper2 path. Did anything change related to Grasshopper2 behind the scenes?
Is Grasshopper.Folders.DefaultUserObjectFolder still there? Fortunately I’ve refactored it to no longer need it, but I used to use this to import custom modules installed there.
It is not!
Weird, I can see them on my system (latest service release):
You’re right, it works again.
