I’m constantly getting this error when Grasshopper loads.
The bottom list changes from time to time but the top always says something wrong with that PluginLoading.txt
This usually happens after …
I added a new pluggin
Rhino crashed last time
Dragging and dropping a .gh file right onto Rhino UI
It appears to be trying to read PluginLoading.txt in “%appdata%\Grasshopper” but if I look in the folder the file is missing.
Sometimes when I get this message it results that several plugins are absent from the ribbon.
the error dialogue seems to come up randomly in my case.
That PluginLoading.txt file seems to be written and deleted on startup.
I think it tracks plugins as they load and only keeps the txt file if a plugin crashes.
I tried to copy the file during loading time to check contents. I repeated several times ad every time It was tracing a different plugin.
My issue was most likely caused by a syncing tool. I have been using this to sync my Gh settings across multiple computers which I find super useful. The tool must have been reading the file at startup which caused the error. Since I disabled I haven’t had that message.
