I just switch back to Windows after having Macs for over a decade. Here I am, already running into issues. Rhino is up to date, as is Panther. That is the only two plugin I have installed.
I keep getting this message upon startup:
Message: The process cannot access the file ‘C:\Users\xxxx\AppData\Roaming\Grasshopper\PluginLoading.txt’ because it is being used by another process.
What does this even mean? And how do I fix it?
I am unable to use Panther or Rhino with this issue.
Thanks!
Stephanie
