Grasshopper error - square geometry series to parametric manipulations
I’ve been trying to make a 10x10 series of square geometries, with different side z height values making up different parametric forms.
There are some unused components due to the past trial&errors, but the main problem is :
As in the [point deform] component, an error keeps popping up showing the [1. You must supply equal numbers of points and motion vectors] sign. Can anyone help me out?
-here is the grashopper file for the error :
10x10 square planes, with different geometric manipulations.gh (21.5 KB)
Happy to have a try, can you supply example without plugin(s).
10x10 square planes, with different geometric manipulations Edited v0.gh (25.6 KB)
OMG, this helped so much.
Thank you so much!!
Regards,
Oh Hajin
