I would like to manually download and store all project- specific plugins in the same project folder where Rhino/GH files are located. The goal is to use the plugins from local directory, making the project more self contained and ensuring long term compatibility and preservation. Ideally , Rhino would automattically load the plugins found in the directory. Any hints how to achieve that?
The most simple solution: Just write a batch file (or let it write by AI) to switch the project context. All it does, is to move the 3rd party plugins from one to another location. You can stick with main plugin location and just move dependencies in and out. You can also start Rhino as second step.
