Hello, my grasshopper and Rhino crash a lot while using grasshopper files where a speckle stream or cluster is present. The files can crash even when the speckle stream is not being used or when the solver is locked. When Rhino and grasshopper crash i get a spinning blue circle next to my cursor for 1 second and then the program shuts down. At this moment i’m using Rhino 7.29 and have removed all my plug-ins, but this problem also occurred with version 7.21. Has anyone else had this problem and how where you able to fix it? Also, is it possible to get crash reports for grasshopper when this happens?
having this issue as well! did you ever find a solution for this?
thanks!
