Command+LMG opens context menu, not allowing me to delete wires. Is there a workaround?
Hi Kurtis-
Do you mean command+Left Mouse Button? What is your expected behavior when you use that?
You should be able to Right-Click an input and use the Disconnect menu.
I’m probably just confused about what keyboard shortcut you are trying to use.
Just a quick note because this topic is related: we have an update coming to the RhinoWIP that will remap some of the default shortcuts. I’ll make a longer Discourse post with details once it is in the field. This is just a head’s up that they are changing (for the better, we hope!) That said, I don’t know that is going on in the case as I we didn’t change keyboard shortcuts related to wire-deletion.
Hi Dan! The latest update has restored what I was having issues with, namely Command+LMB and dragging to delete a wire. Thank you!
