Hi all,
I’m making a shape out of truncated cones in GH:
They way it is constructed is by sampling points on a halved ellipsoid and then extrude them along the normal. The problem I’m facing are empty areas where the base of the cones show up in the opposite side (they will be cut, later on, with a plane on the XY plane, so there’s no need to worry about the bottom side):
The ultimate goal of this is to achieve a distribution of the cones in a way that these gaps don’t appear. Some rules:
- The cones have to start from the surface of the ellipsoid, but they may vary in length if necessary (I tried to avoid this route).
- The radius of the top and bottom faces have to stay unchanged.
- The number of cones can not be increased substantially (by 1 or 2 is acceptable if the problem turns out to be actually impossible with the defined radii).
- The first layer of cones can not be altered in any way, since it relates to other objects (separated list of geometry).
I’ve been looking at circle packing algorithms on surfaces, but either I don’t understand them enough, or they don’t like the ellipsoids, because the results I get tend to push all the points towards the lower edge, and even make the scenario worse:
I have now reached a point where the most time-efficient solution is to select one spike at a time and evaluate a new point in the ellipsoid’s surface and store its position in a list that I manually feed again to work on the rest of the points (internalize multiple times).
If anyone can think of a better solution, please share your thoughts.
-Dani
GH_Challenge.gh (35.5 KB)
