My first guess is that it has something to do with “VisualARQ.Script.dll” as it started happening after an update for that, but i updated Rhino at the same time. Also for some reason it has a reference to a file in a folder for rhino4 and iron python.
Does anybody have any clue if it actually is VisualARQ or if this caused from something else.
I have tried to update to the same VisualARQ.Script.dll everywhere i can find, but it has not helped.
Hi @anders.rudfoss these errors don’t seem related to VisualARQ. But since VisualARQ loads Grasshopper when it loads, it makes that message appear when VisualARQ loads.
Try to open a Rhino session without loading VisualARQ or without running that script that uses VisualARQ (Grasshopper should not load). Then open Grasshopper and see if this problem persists.
Looks like it is connected to another plug inn I have that also uses the VisualARQ.Script.dll.
When disabling VisualARQ on startup i get some additional errors, but by removing the plugins that uses VisualARQ.Script.dll file it seems to work without any errors.
I will have to contact the creators of this other plug inn.
