I’m on test-mode with the new Grasshopper-Archicad live connection.
The Rhino version I’m using is v5 SR13 90days trial, and the last GH 0.9.00.76
The problem appears when I’m using node-components to access from GH to Archicad lists. Then, Rhino crashes appearing a message related to .Net framework or something similar.
Rhinoceros
Version 5 SR13 64-bit
(5.13.60913.21340, 13/09/2016)
Evaluation
SN: 4-1500-1308-100-0003909-30996
Grasshopper
Version August-27, 2014
Build 0.9.0076
Actions performed (steps) The problem is reproducible. It happens every time we use the tool, when you want to use “composite” or/and “surface” component.
Expected and actual results: Every time we insert in the algorithm the “composite” or/and “Surface” component in order to connect them to AC tool setting component. When we want to expand the list of “composites” or “surfaces” , then Rhino crashes. On the other hand, “building material” or “layer” component runs well.
Sorry for the late reply! It’s just that there’s not much we can do since those components are developed by Graphisoft I believe. Have you been able to contact their support?
