Grasshopper / Archicad 29 – Issues with Multiple 2D Exclusion Regions
Hi everyone,
I’m building a 2D landscape planting script using Grasshopper, Rhino 8 and Archicad 29.
I’m trying to subtract multiple exclusion areas (rectangles, irregular shapes and offset curves) from a site boundary using Region Difference.
I’m running into a few issues:
  • Some exclusion areas randomly appear filled when they should be empty.
  • Changing the offset width of a curved pathway sometimes changes which exclusion areas work correctly.
  • Switching exclusions ON/OFF using Boolean toggles can cause Region Difference to return errors or no geometry.
  • I’m struggling to find a simple, scalable way to add multiple independent exclusions.
I’ve tried Region Union, Flatten, Graft, Dispatch and Cull Pattern, but haven’t found a reliable solution yet.
Another issue is that while the geometry is being generated and updated correctly in Rhino, I’m not seeing any of the resulting geometry reflected back in Archicad. I’m unsure whether this is a limitation of the Live Connection for 2D geometry or if I’m missing a step.
What’s the best way to manage multiple editable 2D exclusion areas with independent ON/OFF controls, and how can I get the resulting geometry back into Archicad?
Separately, has anyone worked extensively with the Grasshopper–Archicad Live Connection in architectural practice?
I’d love to connect with anyone using this workflow professionally and hear about potential applications beyond parametric modelling, particularly how Grasshopper can be integrated into everyday architectural design, documentation and practice workflows.
Any advice, examples or experiences would be greatly appreciated!
Thanks in advance!
Landscape grasshopper.gh (17.3 KB)
