Grasshopper 6 Libraries .gha files no longer load in Rhino 8
Hi @stevebaer,
I updated to Rhino 8.9 from Rhino 8.6 and now none of the .gha files from %AppData%\Grasshopper\6\Libraries are loading in the new version. The .gha files do load from other locations. Did the youtrack issue below change the default grasshopper loading functionality for Rhino 8.8 and beyond? We are using the 6\Libraries to deploy legacy tools for many users and would like to know if this location will still be supported.
https://mcneel.myjetbrains.com/youtrack/issue/RH-82035
That issue was to revert an attempt at some new functionality to organize grasshopper libraries that we found messed some items up. The old logic still exists for loading libraries so if something is different between 8.6 and 8.9 for loading your libraries we’ll need to figure out how to reproduce the behavior so we can get a fix in place.
Can you help us understand what steps to take to try and reproduce this?
If you place a .gha in %AppData%\Grasshopper\6\Libraries, Rhino 8.6 will load it and GrasshopperDeveloperSettings will show this location in the “Valid Folders”. Rhino 8.9 will not load the .gha and the folder will not be listed in the GrasshopperDeveloperSettings.
