Grasshopper 2 save problem after August 30 update of WIP
There is a problem now with saving a G2 file…
I have been able to save before this WIP update…
Hi Giusseppe -
Is this file-specific?
no, I also made a small change to a file which had previously been saved in G2 and the same message came up when I tried to save it. This occurs even if I simply quit rhino and respond to the ‘save’ message from G2.
looking into it now…
To be absolutely clear, this broke after a Rhino update, not after a GH2 update? What version of GH2 do you have installed according to the PackageManager?
Please delete all the log files from the diagnostics folder while Rhino is not running:
Start Rhino and GH2 again, make sure logging is set to Verbose:
Save a file, let it fail, and close down GH and Rhino. Then upload the one new log file here:
yes after a WIP update yesterday
Thanks. Final question, is the file you saved actually saved on disk, error notwithstanding? I.e. does the error happen during the save operation, or does it happen after?
it won’t save files any more…ie.fails with the red box message…the files saved from before yesterday are saved on disc, yes.
I do not have the same menu as you show so I am not sure where to find diagnostic folder…will search
You must make sure the Grasshopper window has focus before the GH menu becomes the app menu on Mac OS.
yes, figured that…doing what you asked now
where to bend next……www.metalgarden.ca
(Attachment 73e0bf9d.ghlog is missing)
cannot seem to upload the file
here are contents:
paste log attempt
~#sáe™€8Beginning of Grasshopper log on Thursday, 31 August 2023~#sáe™€3Rhino Build Date: Tuesday, 29 August 2023, 00:00:00~#sáe™€3Rhino Id: 868c63f5-3760-4a45-8600-5399cc57b47c~#sáe™€Rhino Version: 8.0.23241.14306~#sáe™€Rhino License: Beta~#sáe™€Running on VM: False~#sáe™€Grasshopper: 2.0 Wip~#sáe™€User Name: giusseppelund~#sáe™€%Machine Name: giusseppes-MacBook-Pro~#sáe™€OS Version: Unix 13.4.1~#sáe™€Processors: 12~#sáe™€Framework: 7.0.0Äå<táe™€’G2’ command invoked.¨Mzáe™€óBegin loading plugin ‘/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Grasshopper2.dll’ †éáe™€UType assistant for Field ought not to implement both full and partial round tripping.†¶áe™€dInitial construction of ‘Grasshopper.Types.Functions.Standard.FourierFunction’ took 48 milliseconds.fW∂áe™€dInitial construction of ‘Grasshopper.Parameters.Standard.LinguisticCulturePin’ took 28 milliseconds.òJ»áe™€aInitial construction of ‘Grasshopper.Parameters.Special.NumberSliderObject’ took 57 milliseconds.Rfl”áe™€cInitial construction of ‘Grasshopper.Parameters.Special.ConstantPickerObject’ took 39 milliseconds.o’áe™€õCompleted loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Grasshopper2.dll’⁄ÏÚáe™€¶Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2MeshComponents.rhp’ËÙıáe™€™Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2MeshComponents.rhp’(î˝áe™€´Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2TransformComponents.rhp’é&àe™€ØCompleted loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2TransformComponents.rhp’lwàe™€´Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2IntersectComponents.rhp’ä‰ àe™€ØCompleted loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2IntersectComponents.rhp’∫Öàe™€¶Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2DataComponents.rhp’ˆˇàe™€™Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2DataComponents.rhp’d?eàe™€¶Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2MetaComponents.rhp’Fàe™€™Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2MetaComponents.rhp’˙#àe™€¨Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2AnnotationComponents.rhp’"j#àe™€∞Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2AnnotationComponents.rhp’Tø#àe™€®Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2VectorComponents.rhp’–Ÿ(àe™€¨Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2VectorComponents.rhp’@0àe™€®Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2ScriptComponents.rhp’b0àe™€¨Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2ScriptComponents.rhp’¢¥0àe™€¶Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2TextComponents.rhp’\©1àe™€™Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2TextComponents.rhp’¸ß8àe™€ßBegin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2MathsComponents.rhp’ó?àe™€´Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2MathsComponents.rhp'$«Kàe™€©Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2SurfaceComponents.rhp'òcOàe™€≠Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2SurfaceComponents.rhp'fWVàe™€©Begin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2DisplayComponents.rhp'\~\àe™€QInitial construction of 'DisplayComponents.Scene.SeasonPin' took 25 milliseconds.vE]àe™€≠Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2DisplayComponents.rhp'edàe™€ßBegin loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2CurveComponents.rhp'Ójàe™€´Completed loading plugin '/Users/giusseppelund/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8609-wip.28470/Components/G2CurveComponents.rhp'´èàe™€ New Active document constructed.PNìàe™€0Redraw scheduled and delayed for 5 milliseconds.‰ ñàe™€)Empty solution ‘2’ created and completed.."ñàe™€)Redraw scheduled and handled immediately.@8ñàe™€Redraw requested.¨Xõàe™€1Runtime metric ‘Read archive from file.’ started.Ãıúàe™€9Runtime metric ‘Read archive from file.’ completed: 11 ms:ˆúàe™€<Runtime metric ‘Deserialise document from archive.’ started.`%ùàe™€New Inert document constructed.¬,ùàe™€:Runtime metric ‘Document ‘unset’ deserialisation’ started.Pã°àe™€&Adding a new ‘Numberline’ to document.:
¢àe™€3Object ‘Numberline’ successfully added to document.é∫¢àe™€!Adding a new ‘Panel’ to document.˙⁄¢àe™€.Object ‘Panel’ successfully added to document.4(£àe™€&Adding a new ‘Numberline’ to document.65£àe™€3Object ‘Numberline’ successfully added to document.à=£àe™€&Adding a new ‘Numberline’ to document.ÿ=£àe™€3Object ‘Numberline’ successfully added to document.LB£àe™€&Adding a new ‘Numberline’ to document.~B£àe™€3Object ‘Numberline’ successfully added to document.¬S£àe™€BRuntime metric ‘Document ‘unset’ deserialisation’ completed: 40 ms
\£àe™€DRuntime metric ‘Deserialise document from archive.’ completed: 42 msͧàe™€1Runtime metric ‘Read archive from file.’ started.l™ßàe™€9Runtime metric ‘Read archive from file.’ completed: 18 msÓ™ßàe™€<Runtime metric ‘Deserialise document from archive.’ started.ÄW™àe™€New Inert document constructed.ZZ™àe™€:Runtime metric ‘Document ‘unset’ deserialisation’ started.Æàe™€!Adding a new ‘Point’ to document.æÆàe™€.Object ‘Point’ successfully added to document.ËØàe™€-Adding a new ‘Curve From Points’ to document.^∞àe™€:Object ‘Curve From Points’ successfully added to document.DÏ∞àe™€ Adding a new ‘Move’ to document.ñÔ
I don’t think discourse allows the *.ghlog file format. You’ll have to zip it up to post it.
I’m releasing a new version og GH2 now with slightly more granular logging in the save process. Let’s wait until that’s available and then try again.
73e0bf9d.ghlog.zip (2.0 KB)
I am also having problems with Extrusions to BREPs in GH1 on WIP.
seems to be a problem only be on mac…Aug 30 WIP 8 update mac - #4 by wim
Please keep those issues separate!
New version out now. It has slightly more logging detail in the file writing pipeline, will automatically delete logs which are more than a day old, and date-stamped log files. Hopefully the additional detail will let me narrow this down to which part of the process is failing and isolate failures there. And maybe @curtisw will have some insights as well. He knows a lot more about the inner workings of Max OS than me.
log file from new G2…this time Rhino crashed after failed save of GH2 file just as I was quitting
1cd423d7-20230831.ghlog.zip (3.5 KB)
