In GH2 these are Modifiers on the parameter. Add* returns the parameter, so set them right where you register it:
using Grasshopper2.Data; // Modifiers
using Grasshopper2.Parameters; // Access
protected override void AddInputs(InputAdder inputs)
// GH1: pManager[0].DataMapping = GH_DataMapping.Flatten;
var n = inputs.AddNumber("Numbers", "N", "Numbers to sum", Access.Twig);
n.Modifiers = n.Modifiers.WithFlatten();
protected override void AddOutputs(OutputAdder outputs)
outputs.AddCurve("Curves", "C", "Curves");
outputs.AddNumber("Lengths", "L", "Lengths");
// GH1: this.Params.Output[2].Simplify = true;
var s = outputs.AddNumber("Sum", "S", "Sum");
s.Modifiers = s.Modifiers.WithSimplify();
GH1
GH2
DataMapping = GH_DataMapping.Graft
Modifiers.WithGrafting()
Simplify = true
Reverse = true
Modifiers.WithReverse()
GH_ParamAccess.list
Access.Twig
GH_ParamAccess.tree
Access.Tree
Modifiers is immutable, each With…() returns a new one, so always assign it back. Same flags you get from the parameter menu on the canvas, so users can still turn them off.
To set them later, Parameters.Input(0) / Parameters.Output(2) give you the same IParameter.
