If its worth anything, had a student recently get similar errors upon opening grasshopper (no VisualArq tho). We found the issue was he was putting the plug-ins in Rhino6>Plug-ins>Grasshopper>Components where grasshoppers native .gha’s are.
I had him put them in the usual Users>AppData>Roaming>Grasshopper>Libraries and all was fixed.
@cokerone1214 are you by any chance putting plug-ins in the wrong folder?
I don’t think so because when I want to install a grasshopper add-on I open the folder inside grasshopper but I wil check it. Could you please tell me which is the default components only in order to know if there is something different to my components folder?
My assumption is that the problem is related to the order in which the components are loaded, so putting GHA in one folder or in another can change the add-ons load order.
It will take a little to upload. But i have another question. I have a saved file (1-no visualARQ) in rhino before I install VisualARQ.
I have an open rhino window in visualARQ template with another different file (2-VisualARQ) which I work on too where i have used VisualARQ (levels etc). When I open file (1-non VisualARQ) on a new rhino window the same time with file (2-VisualARQ) it seems that the viewport has VisualARQ’s viewport properties too.
I don’t understand your question. What are “VisualARQ viewport properties”?
Can you post an screenshot of what are you seeing that you think shouldn’t be there?
Mm…forget it…It was a kind of lag I suppose. Some lines didn’t appear in the viewport and they were’t hided neither lines nor their layer. Although, it seems that automatic tries to load visualARQ if i am not wrong. Just check this. I try to send you anything I saw which maybe related to the errors.
VisualARQ will be automaticallty loaded in the following situations:
The first time you open Rhino after installing VisualARQ.
If there were any VisualARQ panel opened (Levels or Sections) when Rhino was closed the last time.
When opening a VisualARQ template or any document with VisualARQ data.
When running a VisualARQ command.
If VisualARQ is loading when you open an specific file, then there are VisualARQ information inside this document. You can clean this document from VisualARQ data by running the command “vaPurge” and then saving the document. Take into account that this command will delete all VisualARQ objects, styles and custom parameters.
I am sorry for the email. My fault. I will sent it to you again. So if for example I don’t want to open visualARQ automatically I have to close it last time I close rhino ( levels, section etc ) no matter if I want to open a different file?
And how is possible to close it without loose my information?
