Rhino 7 SR10 2021-9-13 (Rhino 7, 7.10.21256.17001, Git hash:master @ 68677dc86520a0de9485d8b8fa2e841e757733f3)
License type: Commercial, build 2021-09-13
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 9-8-2020 (M-D-Y).
> External USB display device with 3 adapter port(s)
Primary OpenGL: GDI Generic: Microsoft Corporation. OpenGL Ver: 1.1.0
> No graphics device is being used for OpenGL
Secondary graphics devices.
NVIDIA Quadro T2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 4-8-2021 (M-D-Y).
> Integrated accelerated graphics device (shares primary device ports)
- This device is not being used
> External USB display device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 10-28-2020 (M-D-Y).
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
The “Main Display” is conncected to an external USB display port device, which is preventing the
proper video drivers from being loaded by Windows.
- Recommended:
- Use Windows’ Display Settings to configure the laptop screen as the “Main Display”.
- Or, unplug a monitor and plug it into a built-in video port (HDMI/DP) on the laptop.
Then use Windows’ Display Settings to configure that monitor to be the “Main Display”.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 4-8-2021
Driver Version: 27.21.14.6231
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.10.21256.17001
