What is a singular trim? How does it look?
In what context are you using ‘singular trim’? Is this something you’ve read or is there a problem you are trying to solve? More information might help us provide a useful answer…
Hello…
Just trying to export ON_Brep
to ACIS
body.
But for the moment stacked with the WIRE
entity, due to singular trim…
How to create WIRE
entity based on ON_BrepLoop
with singular trims?
Thanking you,
You do know that Rhino already exports to ACIS .SAT files, right?
I don’t know what a ‘WIRE’ entity is - sorry.
Does this structure diagram help?
As far as I understand it, a singular trim is where all control points on one side of a NURBS surface coincide. Easiest example is to create a plane and drag one control point onto one of its neighbours. You should get a singular trim on that end of the surface when viewed in BREP form.
