Graphical issue_Rhino 8
I noticed strange model appearance in both shaded and wireframe mode (attached pictures 1 and 2). It started after installing last update but I’m not sure this is connected. This is happening on two different computers, both with an older graphic card. I saved the model back to version 7 and in Rhino 7 it looks normal (picture 3).
@gorles_82 pls run _SystemInfo in Rhino and post back the results
These are results…
systeminfo.txt (2.4 KB)
the first thing to try is to see if installing the latest drivers resolves this.
Best always to do a clean install
Thank you. When i reopened the file I got notification that model base point is far from origin. Now when I have set model basepoint to origin it works fine. I think that model BP was displaced because I copied everything to a new file and also copied construction plane with base point on large coordinated from original file. But basepoint of original file, where the issue appeared is on origin, so I don’t know… The problem was actually not present all the time but it appeared after working for a while and after software restart it was ok for some time. I noticed before that something similar happens it there is a part of the model very far from origin, so I was checking about this and it was not the cause. So far both files seem to work ok. I will update the drivers and see if the problem comes back…
okay, yes in that case these display artifacts can happen. A driver update won’t help with that.
Yes, I guess it was most probably just my mistake associated with large coordinates. I’m sorry about that…
I think I have found the cause. I made a CPlane for exporting to Autocad, which is far away from origin. When I set up this CP in plan view as current, the symbol is shown in perspectice view and it messes up the graphic display…
Hi GorLes -
I’m not seeing that behavior in a quick test here with a custom CPlane that is at 2.5M,3.5M,300 from the world origin. Please post or upload the 3dm file so that we can take a closer look.
this is the file. I noticed same behaviour with other files too. On coworkers computer with newer graphic card this doesn’t happen though. I updated graphic drivers and it doesn’t help.
3D 003.3dm (9.3 MB)
Hi GorLes -
Thanks. I see that behavior here and filed this as RH-87877 Display: FFO Custom CPlane Widget Messes Up Display
