Graphical Element Can't Bake or Get Geometry from Detail Item
I’m trying to get curves from a Revit Detail Item, “Graphical Element” doesn’t work. Is there a practical way?
Detail Items are View Dependent, use the Element View Geometry component.
Thank you Japhy!
Hey Japhy, similar issue for Railing but can’t use the same solution.
Yes, if you get just the Railing it doesn’t include the Top Railing (similar to getting a Curtain Wall, the Panels and Mullions are separate)
You can use the Element Dependents to gather, or query the category
Got it, make sense, thank you Japhy
