Graphic issues
Some graphic issues
Rhino 8 SR0 2023-9-28 (Rhino 8 BETA, 8.0.23271.13234, Git hash:master @ 4acd4a788d5f9e7999c3d49c07cdd2f60038b920)
License type: Commercial, build 2023-09-28
License details: Cloud Zoo
Expires on: 2023-11-12
Apple macOS Version 13.5.2 (Build 22G91) (Physical RAM: 96Gb)
Mac Model Identifier: MacPro7,1
Language: en
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
AMD Radeon Pro W5700X (16 GB)
BenQ PD2700U (2560 x 1440 @ 30.00Hz)
BenQ PD2700U (2560 x 1440 @ 60.00Hz)
USB devices
Apple Inc.: USB-Serial (0001)
Verbatim: STORE N GO
Kingston: DT microDuo
Realtek: BillBoard Device
GenesysLogic: USB3.1 Hub
9726-200619: Integrated Camera
Apple: Headset
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Users/pasvaz/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/DatasmithFacadeCSharp.dylib
/Users/pasvaz/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Iris.Mac.rhp “Iris” 1.0.0.0
/Users/pasvaz/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp “Datasmith Exporter” 4.27.2.0
/Users/pasvaz/Library/Application Support/McNeel/Rhinoceros/packages/8.0/maxwell_rhino/Maxwell for Rhino/maxwell_rhino_8.rhp “Maxwell for Rhino” 5.2.6.5
/Applications/RhinoBETA.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.23271.13234
can you give us some detail about the problem you are seeing ?
Maybe it is the doubling up of toolbar buttons in the first image
Can you see the lines? Are not designed from me. Also isn’t possible select the objects because mouse pointer start every times from left of perspective view. And if I select a single object it select another one. I’m sorry for my English…thanks
Hi Pasquale -
Are you using two monitors, and, if so, does the behavior change when you disconnect one?
Also, have you tried disabling the 3rd party plug-ins and restarted Rhino?
Finally, if you could post a simplified 3dm file that shows unwanted behavior, we could see if we can reproduce that behavior here.
Thanks,
If disconnect one of two monitors it works! Great!!!
if i open rhino 7 it has same issue and visual problems like this
quite a disco going on there
Hi Pasquale -
This is a known issue on older Macs with a Radeon GPU.
In Rhino Preferences -> OpenGL, uncheck the GPU Tessellation option.
