Grant permissions
Hi
Rhino is asking me to confirm my login before launching, and I see this screen first.
2020-04-02 11_01_18-Rhino Accounts – Grant Permission
But then when I press allow I got redirected to the link with localhost:
https://localhost:1717/?code=eyJhbGciOi
And eventually I can’t launch rhino. Can you help please?
This looks like chrome. You need to make sure connections to localhost are allowed.
The question here is if localhost:1717 is the right address? Shouldn’t it be McNeel address?
This didn’t help: chrome://flags/#allow-insecure-localhost
The localhost:1717 is where the authentication process redirects to after you’ve signed in to your rhino account. Here the result is communicated to your Rhino instance.
Fiedler is displaying this:
HTTPS handshake to localhost (for #134) failed. System.IO.IOException The handshake failed due to an unexpected packet format
I had the same support case today.
(From https://wiki.mcneel.com/rhino/install/wizard/start/windows/6/commercial/czpersonal/firewall)
The default web browser was Edge. The three websites above could be accessed. Proxy was disabled. Rhino did run on the computer before. The problem appeared a few days ago.
I fooled around on the computer in a remote session for a while. In the end, resetting Edge fixed the problem. Before Resetting Edge, Chrome had the same problem. I don’t understand why.
