Is there any universal, fast and simple way (without using many components and without Path Mapper and Entwine) to “graft” items from indices to first main branch ( not the last sub-branch)?
Thanks in advance!
Do you mean like this?
Here you right click on the output of the component, then select Graft, and Simplify.
Unfortunately not. I meant {A;B:C}(i) —> {i;A;B:C}
Flip and Graft?
I’m guessing again that its not going to be so easy. Its hard to know without seeing the data you are working with.
I’ve showed data structure: I have this {A;B:C}(i) and I need this {i;A;B:C} (the content is not essential).
I don’t want to use Entwine and Path Mapper, because they are not universal ( You have to manually adjust number of branches).
