Just a small usability suggestion. Is it really necessary to click the EDIT button to be able to change the points? Why not make it as in the spotlights? They also have control points that are not strictly geometry but you can edit them as soon as you select the object.
Another issue would be the display order of the hatches, cause it changes a lot the results when they are overlapping. In the example, black&white gradient with 50% alpha.
it is much faster than rhino 6, but unfortunately with textures it is still difficult. the textures I mean are small shapes such as 1 mm balls repeated on a flat or hemispherical surface. I put an example in the image
Thanks Steve. Any update on this as either gradient or solid transparency for vector objects would be a seriously good tool to have when printing pdfs. Is there any open source for PDF export from Rhino as I would like to try and code if there was an opportunity to get this feature.
Loving all the hatch enhancements. ie Gradient and Transparent hatches as well as the ability to trim hatches!
There is an old v6 behaviour that I miss and that’s the ability to change the current layer mid-command. This still works for most other commands, but isn’t currently possible for hatches.
