it´s me again… …well… i don´t know how to explain…
accidently i got 12x ATI R9…
they are on poor Rigs, bad CPU, not much Ram, just 3x R9 GPU per rig…
Linux is installed…
so… how can i take advantage with Rhino?
i use Vray for rendering. Do you think i yould use the GPUs with Vray RT for RT rendering?
Will the results in a big resolution like 14000x10000 be displayed well? nice sharp and chrisp?
with my old GPUs the RT engine seemed useless until now… but this crazy setup opens new dimensions??? am i right or should i install some DR spawners on them ^^ ?
I dont think you will be able to make that large renderings, i think they have about 3gigs or ram each? thats not enough, it just speeds up whatever fits in the Vram but it has no virtual memory possibilities to adress when the file (due to the resolution in your case) exceeds the 3gigs of ram,
Not expert on Linux but Vray for Rhino only works for win, at the moment.
Maybe you can get the DRspawner working under wine.
VfR 2 work also for ATI using OpenCl.
If I would you I’ll install a fresh win7 and have lot of fun
It doesnt work like that, you should see each card as a seperate pc, its 3gigs each, i have 2 nvidia 760gtx 4gb, doesnt mean i have 8, it means i have 4 and 4,…
Talking about final rendering it depends on which kind of effect you want in your scene. RT doesn’t support all the material effect so could be a problem.
But if you are doing just a normal rendering RT it’s exactly like normal.
Instead of waiting for passes you have to wait for noise refinement
With 3 big ATI card it’s sure better to do RT.
Ps: yes RT works on distribute. The problem could be ethernet delay.
i do a lot of postproduction. so i guess for my use using the rig should help a lot in saving time…
i rendered 2 Days because of bad settings and material on this image:
after that some postproduction:
e voila… so its usually a groundplane with some normal mapping, some glass with reflection/refrction and puh… very seldom some displacement. but i try to avoid…
Its just the waste of time when you combine some materials that makes me mad and the wish for a faster rendersolution bigger… And just having the rigs for mining and heating is hm… …could be used better.
