Hi all,
I have a super quick yes-or-no type of question:
When I sub-select a SubD face or a loop of faces, is it possible to change the subselcetion to the corresponding vertices or edges?
If no, ok. If yes, what’s the command?
Thanks ![]()
Hi all,
Thanks ![]()
You’re looking for SubDFaceEdgeVertexToggle, I believe
That is a polar question or closed question, I think. ![]()
@pierrec, is there an equivalent command for meshes that are not SubD?
Thank you
None that I know of, sorry.
Hey, Pierre
If I’m not mistaken, in the old T-Splines, one can seamlessly switch selection from a Face to a Vertex by simply pressing the Vertex Select Mode while those Faces are selected . And you could do this easy switching from every combination - Face to Edges (Press Edge Select Mode), Edges to Vertex (Press Vertex Select Mode). This is so much easier and discards the need to press a different hotkey or type command. Why not just implement this?
