Globally editing multipule instances of a text string in R5
In Rhino 5 is there a way to edit multiple instances of a text string (in one drawing) globally / simultaneously? Example: The text “123” appears multiple times in a drawing. It will be necessary in the future to change all instances of that text to a different number, say “124”. Is there a way to link all instances of that text so that if it is changed one place in the drawing all linked instances of that text will be changed across the whole drawing?
Hello - using blocks may be what you are after - assuming you want the entire text to be the same - if not, if you want some specific subtext to be modified in multiple different strings of text… you’ll need a script, I think.
Got it now. Perfect. Thanks much!
