Hi everyone!
I have two lines that intersect at a common point. The endpoint of each line is located at a different position in space. I want to rotate one of the lines around the common point of intersection so that it aligns with the other line while maintaining its original length and keeping its common endpoint fixed in position. The other line is allowed to change its length, but its points must remain fixed in position. In other words, I want to find a transformation that rotates the line around the common point of intersection while preserving its length and position, so that it lines up with the other line.
Cross Product V0.gh (23.7 KB)
There are two random lines red and blue.
The red is fixed, blue is moving.
Green is the moved blue.
Black is a cross-product vector of red and blue.
WOW.
Honestly, i don’t really know how to proceed from here or what is going on in the gh file you attached(which is amazing). I’ll keep learning and investigating the file you sent/ again; it is amazing! Thank you
