Global Edge Continuity - Release Candidate now on packagemanager
I used the method you posted here
me neither, but worse is a edge pair marked G2 that is not. Consider the following example file:
incorrect G2 flag.3dm (12.5 MB)
in previous version, all edges (except the 3 G0 ones) are marked G2, because their abs. tolerance is well within specs:
In new version, I get this:
which IMO is much more accurate feedback, apart from the edges that meet the flat surfaces.
So I am thinking: what might be a good way is to mark edges G2, if their rel. tolerance is low enough (currently -0.5 < rel < 0.5 ) and abs tolerance is within specs OR if abs tolerance == 0
This would then yield this result:
