Glitches in shaded viewport and renders - two solids, no overlap
Could you help me understand and/or resolve this rendering issue?
It occurs in shaded display mode and when rendering with V-Ray.
The scene (a theater) is relatively large, though not exceptionally so. The problematic object is located in the center of the scene. This object is a closed solid polysurface, created by extruding a planar surface along a guide curve. The object and the scene do not overlap ! The outer (visible) surface of the object is positioned 2.60 mm away from the surface of the scene. When the object is displayed on its own, there are no display issues.
The problem disappears only if the object is moved 6 mm away from the scene…
The issue persists despite the following tests :
  • creating the object from a planar polyline instead of the original surface;
  • creating the object from the planar surface, but with subdivision at tangents;
  • increasing the NURBS mesh density;
  • performing an analysis using TestZBiasFactor.
Thank you in advance for your feedback.
Rhino 8 SR35 (8.35.26251.13001)
Vray 7.40.02
Win 11 Pro version 26H2 (10.0.26300)
Nvidia Studio 610.62
render-issue.3dm (2.8 MB)
How far is this object from the world origin, and what are the model units and absolute tolerance? Faces 2.6 mm apart that only stop flickering at 6 mm sounds like it could be z-fighting from depth precision in a large scene, so the camera clipping planes might matter too. Interested to see what the fix turns out to be.
And z buffer issues can happen even close to the otigin if there is a very large object, c but the model is zoomed into a small area. Z buffers have a limited number of depth levels.
The small object is positioned at the origin of the scene.
The total surface area of ​​the scene is approximately 800 m².
The file was created—for no apparent reason—with an absolute tolerance of 0.001 mm. Could this choice be one of the causes of the rendering issue ?
I ran a new test: I scaled the scene down to approximately 5 m². With a scene of this size, the problem disappears !
So… What precautions should be taken, or what solutions exist, to avoid similar issues when dealing with a “large” scene ?
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Commercial, version 2026-09-08
License details: Cloud Zoo
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 31GB)
.NET 8.0.32
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 5070 Ti (NVidia) Memory: 16GB, Driver date: 6-11-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.62
Accelerated graphics device with 4 adapter port(s)
Windows Main Display attached to adapter port #0
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 8-17-2026 (M-D-Y).
Accelerated graphics device with 5 adapter port(s)
There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-11-2026
Driver Version: 32.0.16.1062
Z-Buffer depth: 24 bits
Total Video Memory: 16303 MB
C:\Users\steph\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\byRhinoGadget\1.6.1\byRhinoGadget.rhp “byRhinoGadget” 1.6.1.0
C:\Users\steph\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rendu de Rhino” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
Hi @Stephane_Thonnard
Without seeing the actual geometry (not at a PC right now), my best bet is that this is a render mesh issue. The slight curve and the skinny object is one of those things that the default render mesh settings suck at. Try going to “smooth and slower” if you are on “jagged and faster”. Or go to detailed options and set everything to 0, except for “max distance, edge to surface” - set that to 0.1 and see if that works.
Or
HTH, Jakob
During my tests, I had set the overall rendering mesh quality to “smooth and slower,” but it didn’t change anything.
@Jakob, I tried your solution, and it works !
The parameter that bypasses this problem seems to be “max distance, edge to surface.” Increasing its value to 0.1 was enough for this scene.
Rather than applying this parameter to the entire file, I only applied it to the two objects in question (custom mesh parameter).
Thank you all for your feedback, and especially to you, Jakob Normand !
