Glitch when rotating view
When I try to rotate the view in perspective, the form starts to glitch in a bunch of different colors. This only shows up when it’s in Shaded view.
(idk if the video will upload correctly, if it doesn’t i’ll try to upload screenshots.)
In the vid its a box and a patched surface. I started noticing the issue with a surface I was working on, but then noticed that it happens with simple shapes as well.
I’ve been using Rhino7 since January but only recently (1-2 months ago) started getting this problem. Haven’t switched laptops or anything. No other problems with my laptop or with Rhino7. When I looked through the forum I only saw glitches with lines and shading, nothing with random colors like this. plz help
Hi Zarrina - please run the SystemInfo command in Rhino and Copy/Paste the results here.
I ended up also emailing tech support, and I got the issue fixed. My graphics chip was not enough so I updated it
